tech help. no power above 4500 and o2 sensor
Old May 20, 2014 | 05:24 PM
typeRef's Avatar
Default tech help. no power above 4500 and o2 sensor
ok i got a 89 LX sedan that i did a mpfi swap in.
problems are - no power above 4500 rpm and the o2 sensor CEL comes on after only driving a few blocks.
mods are CAI, adj cam gear. other then that its all stock.
known issues other then the above is small exhaust leak at exhaust manifold to downpipe. 1 of the 3 DP studs are broke.
i had a chipped ecu in it and the only time the o2 sensor CEL would come on was when under a heavy stress. like going up a hill driving into the wind. in an attempt to get better mpg i put the stock ecu back in and retimed the engine. the timing is dead in the middle of the 3 notches.
when trying to give it some throttle, once it gets around 4500 rpm it bogs down big time, almost like a reverse vtec. it does go all the way to rev limiter but it sure takes time to get there.
im open to any ideas or suggestions. things to check.
Old May 20, 2014 | 06:04 PM
SpeedOFsmell's Avatar
Default Re: tech help. no power above 4500 and o2 sensor
do a compression test. check your plugs. sometimes a gap that is too large can cause high end/high load missfires.
Old May 20, 2014 | 06:06 PM
TypeRfit's Avatar
RESIDENT
Check your Catalytic converter. I ran into the same problem in my Integra and that's what the problem was
Old May 21, 2014 | 04:41 PM
typeRef's Avatar
getting a hollowed cat tomorrow to try in place of it.
Old May 21, 2014 | 09:43 PM
4drEF's Avatar
Keyboard Humorist
Remove the cam gear and sell it. No point since its a stock engine
Old May 23, 2014 | 07:26 PM
^yup
Old Jun 27, 2014 | 06:41 PM
typeRef's Avatar
took the stock cat off yesterday and it looks brand new inside.
and the head is a y7 head so ill keep the cam gear on it.
Old Jun 30, 2014 | 08:06 PM
typeRef's Avatar
took ecu out and found out it was chipped. ive tried other ecu's that i assume were stock and the engine wouldnt rev past 2500. so it appears that my sedan only runs on chipped ecu's.
Old Jul 3, 2014 | 03:19 PM
typeRef's Avatar
also did some more research on the b2/y7 mini me and i did not realize you need to run the 88-95 civic cam gear. not the y7 cam gear. my adjustable gear was set to be the same as the y7.
im hoping now that this really fixes the problem.
bmoreb18c1
Aug 13, 2012 01:14 AM
jkm808
Aug 3, 2009 06:31 PM
90_Si
Aug 17, 2007 11:31 PM
CNSK
Oct 6, 2005 10:27 PM
maxxdout
Jul 8, 2002 01:31 PM
