Moly Lithium + caliper pins
I have a 1994 Honda Accord EX.
Is it safe to use Moly Lithium for the front brake caliper pins?? (I didn't have any caliper specific lube at the time) Should I remove the pins clean the caliper and start over with new pins and boots??
I've scoured the net and I can't find anything that definitively says you can't/shouldn't.
The Chilton's manual I used doesn't specify anything.
the important thing is to use a high-temp grease. anything else will get cooked when the brakes heat up. this will typically cause the caliper to drag, bind and even freeze up.
I like Sil-Glyde, there are other caliper pin specific greases available at your local auto parts store. some work better than others but all are safe to use.
ButterBall
12
Jul 3, 2009 11:08 AM
rasinhell
Dec 2, 2007 03:33 PM
More&Faster
Dec 18, 2003 03:52 AM
