VAFC on PR3 (VTM signal)?
Old Oct 30, 2002 | 12:47 PM
PhatOptimo's Avatar
Default VAFC on PR3 (VTM signal)?
HI, All I just installed my VAFC. I am looking through the instructions now. I was wondering where to install this wire? I am looking for the pinout letter and #. I read that some don't use this wire. Is the PR3 one of them? TIA
Old Oct 30, 2002 | 12:54 PM
Rob!'s Avatar
Default Re: VAFC on PR3 (VTM signal)? (Phat_Optimo)
off topic but which one did you get? i wanna get the APEXi one thanks
Old Oct 30, 2002 | 12:55 PM
Urban Business
Guest
Posts: n/a
Default Re: VAFC on PR3 (RaceFacer)
if the apex diagram shows no VTM signal on the ecu diagram its not used.
Old Oct 30, 2002 | 01:01 PM
PhatOptimo's Avatar
Default Re: VAFC on PR3 (TorteX)
Its the apex I unit.
Its not clear. To me anyways. I was looking for someone who knows for sure.
Old Oct 31, 2002 | 02:33 PM
rioninja's Avatar
VTM is just the oil pressure switch next to the solenoid. Basically just cut the VTM wire as it comes out of the ECU, and attach it to the VTW wire to the VAFC. The VTW wire is definatly in the diagram. If it isnt, just download the newer manual from apexis website.
If you plan on raising the vtec X-over above stock, then its true that you dont have to hook it up. If you lower the X-over below stock, you will need it or you risk losing a few HP.
hondaZvic
Aug 6, 2004 11:40 AM
hatchback_al
Jun 15, 2004 08:48 PM
racinskittle
Sep 27, 2003 09:44 PM
bumpin_bass
Jan 10, 2003 02:32 PM
Accord_Munch
Dec 5, 2002 06:36 AM
