Cel code 4 after washing motor
Old May 19, 2014 | 02:59 PM
Mag00n's Avatar
Default Cel code 4 after washing motor
I'm selling my car soon and recently sprayed the bay. I was careful not to directly spray electrical connections, dizzy, battery etc but right after the wash I'm getting cel code 4(ckp/dizzy) (it's a 2000 civic running a p28 with a harness) it's been about 24hrs, I popped the plug wires, the cap, and all the connectors around the dizzy and I'm letting them sit. Also reset the Ecu several times.Is there anything else I can do?
Old May 19, 2014 | 03:43 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Cel code 4 after washing motor
You could start praying that you didn't fry the CKP. There's a reason you shouldn't ever pressure wash an engine, and this is it.
Old May 19, 2014 | 04:00 PM
Mag00n's Avatar
Wasn't pressure washed just my house house..is the ckp part of the dizzy or separate?
Old May 19, 2014 | 04:08 PM
NotARaCist's Avatar
I'm always getting the CKP and CFP mixed up, but I believe the CKP is part of the distributor, yes.
There are a LOT of electronics in there. You should never spray water in there. The engine bay is brush and bucket of water territory.
Old May 19, 2014 | 04:49 PM
jdm_ek_noob's Avatar
Yes, it's part of the dizzy. I had CEL 4 before. I replaced the dizzy and the code went away. You might want to borrow someone's dizzy and see if the code goes away
OR, it could be the distributor harness (the group of wires that connect to the distributor plug). Rywire has dizzy harnesses for like $30. I have one and it cleared my CEL 8 code, which is also related to CEL 4 since both codes refer to different sensors in the dizzy, and/or the wires that are part of the dizzy harness.
Old May 19, 2014 | 06:58 PM
Former User's Avatar
Use an air compressor to blow dry ALL engine bay connectors. Then reset the ECU and go from there.
Old May 26, 2014 | 09:36 AM
Mag00n's Avatar
Swapped dizzy code is still there checked resistance of dizzy with multi, anyone have any ideas I hate electrical issues
Old May 26, 2014 | 02:17 PM
Mag00n's Avatar
Also when I plug the stock Ecu in I get a code for the 2ndary 02 but no dizzy code
Old May 27, 2014 | 10:23 AM
Mag00n's Avatar
Resistance at the ecu connector and the dizzy connector are both within spec (380)
Hoffer 10
Engine Management and Tuning
Aug 20, 2012 10:02 PM
b16a1eg6
Jan 17, 2007 03:32 PM
Gixxerboy02
Apr 30, 2006 01:16 PM
89civichatchback
Feb 26, 2005 03:44 PM
Akira-R
Jul 22, 2002 02:00 PM
