'99 Prelude Front Lower Ball Joints
Old May 19, 2014 | 03:43 AM
MKCSRet's Avatar
Default '99 Prelude Front Lower Ball Joints
During my engine swap, I sheared the passenger side lower ball joint bolt trying to remove the castle nut.
Is this lower ball joint renewable or do I need to purchase a whole new Knuckle ?
I tried the search bar, to no avail. Any advice would be most graciously appreciated.
Old May 19, 2014 | 08:27 AM
afrotec's Avatar
Default Re: '99 Prelude Front Lower Ball Joints
What do you mean...are you asking if the lower balljoints are removable/replaceable? If so, then yes, they are replaceable. You would need a good hammer, a ball joint separator, and a ball joint press to press the new one in. Procedure is here: http://www.jdmpowerhouse.com/diyballjoints.html
This is the single balljoint: 51220-SL5-013 ($58.25), or this TSB kit will give you 2 lower ball joints for less: 04510-SL5-000 ($41.64)
More info on the parts here: http://www.preludepower.com/forums/s...d.php?t=349707
Old May 19, 2014 | 09:51 AM
MKCSRet's Avatar
Oh, Thank You ! I was just about to buy the whole Knuckle. Time fore more research. Thank You !
More to follow,
Old May 21, 2014 | 08:40 PM
Sakanora's Avatar
It's a PITA to change, if the whole knuckle isnt too much more I'd rather get the knuckle.
Old May 22, 2014 | 06:33 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The ball joints are priced at under $50 for both, according to the guy above. A knuckle is not close to $25.
Old May 24, 2014 | 03:52 PM
Sakanora's Avatar
Then get the ball joints, the biggest problem is the snap ring, make sure you have the proper snap ring pliers, also take the whole knuckle out instead of working under the car, it will save you a lot of trouble and frustration
boost4life1
Apr 17, 2012 04:58 AM
c1v1c98
Jul 6, 2010 04:50 PM
halocore
Mar 7, 2009 04:34 PM
Menace2Society
Dec 15, 2007 06:23 PM
97hb
Mar 9, 2002 11:31 PM
