Low idle after ECU change
Old May 18, 2014 | 05:29 PM
thehig's Avatar
Default Low idle after ECU change
Changed my ECU from stock to a chipped ECU P28. Everything was smooth but have super low idle. Was told to disconnect IAVC and adjust the idle screw. Want to make sure thats the best thing to do before I do it. Also if so can anyone post a pic of the idle screw. 98 Prelude
Thanks
Old May 18, 2014 | 11:40 PM
holmesnmanny's Avatar
Default Re: Low idle after ECU change
There is obviously something wrong with the program of the chipped ecu, likely the idle rpms set point is too low or the base map is wrong. Don't go changing the idle adjusting screw if the stock ecu works fine with its current setting.
Old May 20, 2014 | 06:05 AM
thehig's Avatar
The stock one was a little low. Think I should just send it back to him and have the idle point set right ?
Old May 20, 2014 | 06:38 AM
snobordboy's Avatar
Moderator
How low is low? If it still stays running, maybe it just needs a few ecu cycles to even out. Depending on what your idle is set at in the ecu, you may need to adjust your idle screw on the TB as well.
Old May 20, 2014 | 09:21 AM
take the iacv off and see if the metal outside filter is gunked up with carbon first
Elitesky
Jul 10, 2010 01:23 PM
candy eg
Aug 17, 2006 02:22 PM
89_crx
Apr 18, 2005 06:26 PM
94SiSQO
May 3, 2002 02:46 AM
