anybody done a h23v swap in an integra in NC
Old May 16, 2014 | 01:31 PM
H23_FrankinTeg's Avatar
Default anybody done a h23v swap in an integra in NC
Im in the Wilmington/Jacksonville area and am having wiring issues with the swap. it runs but my alternator is not charging the battery and my vtec dosnt work. i have a P28 ecu.
Old May 16, 2014 | 02:54 PM
SpokaneSpeed's Avatar
Default Re: anybody done a h23v swap in an integra in NC
Have you tested for continuity on the wires at VTEC solenoid. One at a time, test from the plug, back to the pin at ECU for continuity. Also verify you have them going to the correct pin at the ECU plug.
What harness did you use? Have you verified that the alternator is good? (i.e. taken it off and had the local parts store test it).
Old May 16, 2014 | 03:01 PM
the guy i got it from cut and spliced almost every wire in the car none of the colors match and im new at the electrical aspect. it looks like spaghetti, i dont even know what wire harness is in here. its a nightmare.
Old May 16, 2014 | 03:05 PM
Just start over with a different harness man. You're going to drive yourself crazy running down wiring issues in a mess like that...
Old May 16, 2014 | 03:13 PM
thanks man i might have to im looking up the up the wire diagrams now but id rather have someone experienced by my side to steer me in the right direction.
DVDr
Jun 22, 2015 06:43 PM
pr0honda
Oct 21, 2009 09:22 AM
shbrown
Aug 11, 2005 04:51 PM
y_do_u_want_gio
Jan 4, 2003 07:32 AM
