D16Y7 Seized up and dont know why???
Old May 15, 2014 | 09:45 AM
DeeNASTY_'s Avatar
Icon2 D16Y7 Seized up and dont know why???
So one day I was driving home one day in my 98 ek hatch and my timing belt snapped. So I pushed the car into a parking lot off the road and went to go time and put on a new timing belt the next day. After everything was done and i turned the car over I started hearing a really loud knock but I was able to drive the car home. When I got it home i didnt turn the car on till the next day and assumed the knocking was from the head. So I did my valve adjustments to see if that was the issue and the noise was still there. Then I went to get a new head to replace it and still had the knocking. So I went under and drained the oil and then got the oil pan off. Then when i did that I found out I had a spun bearing so yeah I was having a rod knock. So I left the bottom end open for 2 days waiting for the new bearings to come in. So as I was putting the new bearings on, I noticed I was able to push piston 1 and 4 all the way up and down to be able to get the top bearing but then noticed that 2 and 3 would only move a little up and then stop and not move no more. So I thought it was no biggy. And I did have the spark plugs out so I would have compression. But so I tried to turn the engine manually but wouldnt budge neither counter-clockwise nor clockwise and when I went counter-clockwise it was stuck to the point where I could un-bolt the pully. Hence before i took drained the oil and etc. the car would turn over. Anyways I didnt think nothing of it so I put the new bearings along with a new oil filter also new oil. After bolting everything back on. The car wouldnt start or anything and my friend that was helping me realized at that point the engine seized. We dont know how or what caused it to seize. Any ideas???
Old May 16, 2014 | 11:10 AM
turbomaniac's Avatar
Default Re: D16Y7 Seized up and dont know why???
to much info on this....
ia assume that after timing belt, there must be several problems that caused a f...d up engine.
does the crank rotates?
if no strip the engine and built it again.
if yes do a compression test and post the results
Old May 17, 2014 | 03:32 AM
grumblemarc's Avatar
The Grumpiest
What's the point? Get a new engine and maintain it. This one obviously was not.
ratchetEDsedan
Sep 5, 2017 04:49 PM
GoodSkoolRevltn
10
Feb 15, 2015 05:41 PM
cmamtower
Mar 10, 2010 07:10 PM
sipolt89
15
Dec 29, 2008 03:04 PM
SilverEk3dr
Aug 20, 2002 04:24 PM
