93 Civic Rough starts
Old May 14, 2014 | 07:38 PM
lilhatch89's Avatar
Default 93 Civic Rough starts
I have a 93 Civic EX, When I go to start it it gives me trouble. I have to hold the gas in or pump it to get it to start, When it finally catches, it runs for a second like its miss-firing, Then clears up and runs smooth as can be, I can drive it around all day. Car has great power and no hickups once its running. I have already replaced the Distributor, TPS, Main Relay, and Map Sensor. Also Car is running on a p06 thats been converterd to p28. I have swapped the ECU out with a p30 i have just to see if it goes away but problem persist. Any help would be appreciated. Engine is a d16z6, Was just converted to 5 speed. The problem first started before the transmission swap, It would start up with out the gas being held but a have a slight miss-fire on startup for a split second and clear up, Seams now the problem is getting worse as it is requiring the gas to be pumped/held in.
Old May 15, 2014 | 04:30 AM
lilhatch89's Avatar
Default Re: 93 Civic Rough starts
Anyone
Old May 15, 2014 | 05:36 AM
BudWheel's Avatar
Just a hunch but look at I believe its called that ECT sensor. Its the 2 wire plug while facing the engine left side of head just above block. Mine was doing the same thing before I fixed that. I had to go to a junk yard and cut the plug and rewired to my car. Mine ran rough till it warmed up and then ran fine. Maybe you messed up the wiring when you took out the transmission?
Old May 15, 2014 | 08:36 PM
One92Eg6's Avatar
Fuel pump might be going bad.
Old May 15, 2014 | 08:57 PM
BudWheel's Avatar
Yeah but would it not run correctly at all times if it was the fuel pump?
Old May 15, 2014 | 10:47 PM
turtlegrip's Avatar
No
Old May 16, 2014 | 12:16 AM
titusvillesedan's Avatar
Unless you did some weird mod, you should have fuel injection. ( obvious I know ) So if it was fuel related, pressing the gas pedal wouldn't have an effect on how much fuel there is for startup whilst cranking I mean. But it def sounds fuel related. I would agree with the fuel pump, but add, it could also be the pressure regulator conflicting with the PCM/ECM
Mikestewart
Aug 8, 2016 09:09 AM
AgentOrangeex93
Aug 19, 2015 08:52 PM
aaronl29210
Sep 29, 2011 06:00 PM
vdubdave91
Aug 30, 2010 10:35 AM
madball
12
Apr 2, 2007 05:10 PM
