Skunk 2 throttle body install help
Old May 14, 2014 | 12:45 PM
marshall12395's Avatar
Default Skunk 2 throttle body install help
Just installed 74mm skunk 2 throttle body and there's some left over hoses I thinking there vacum hoses do they just get block of or should they be connect somewhere else
Thanks
Old May 14, 2014 | 01:10 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Skunk 2 throttle body install help
You either need to be more descriptive or provide pictures because you are being very vague.
Old May 14, 2014 | 02:29 PM
ef2_civic's Avatar
Correct.
Is this a k series or b,f,h, d series
Old May 14, 2014 | 04:40 PM
soaringchimp's Avatar
You don't need the hose. I don't know why its still included.
So long as you are running an aftermarket intake manifold with an oversized inlet, used the gasket it came with, calibrated your TPS and have the coolant line that used to run to the throttle body run back to the IACV on the back of the manifold directly you are good to go.
Old May 15, 2014 | 08:17 AM
Sorry it's 1997 b18c and the coolant hoses on the back of the intake goes back to the iacv and those vacum hoses just blocked of?? Thanks
waynesumner
28
Feb 12, 2026 03:51 PM
95ccoupe
Jun 28, 2007 08:33 PM
chadmasterc
Mar 1, 2006 07:06 PM
TyeJ23
Aug 31, 2005 07:52 PM
