Question about exhaust and crankcase pressure?
Old May 13, 2014 | 10:19 AM
jdragon1974's Avatar
Default Question about exhaust and crankcase pressure?
So quick question. If your running lets say 12:1:1 comp and and lets say 2.25 header to 2.25 pipe to 2.5 exhaust would this have an effect on crank case pressure. Also would you run a different breather set up on this comp instead of the "black box"?
Old May 13, 2014 | 10:40 AM
93egSLEEPER's Avatar
Default Re: Question about exhaust and crankcase pressure?
What kind of block? That is the first obstacle.
Old May 13, 2014 | 11:04 AM
Pro-SeriesFab's Avatar
This is going to sound dumb but crankcase pressure comes from pressure escaping into the crankcase . . . the main way it gets there is past your rings through the end gap and to a smaller degree during flutter if you can't control them at high RPM and how loose you have set piston to wall clearance, etc.
The greater you make cylinder pressure, the greater the likelihood of the rings not being able to control all of it when the variables are held constant. A more effective exhaust scavenges the combusted gasses easier but still doesn't effect the peak pressure within the cylinder that much.
Old May 13, 2014 | 11:10 AM
OK interesting, so I have a gsr block with ls crank and eagle rods, with b16 head, should I set up a better system then the black box? Good info thank you.
Old May 13, 2014 | 11:11 AM
Gsr blck, ls cank ls eagle rods with b16 head. Oh and 0.10 off the block and 0.15 off the head.
Old May 14, 2014 | 10:27 AM
Anybody have a clue? Lol
Old May 14, 2014 | 02:48 PM
The exhaust should not directly effect crankcase pressure. If the exhaust is giving you that much back pressure there would be other concerns as well.
Old May 14, 2014 | 05:41 PM
Yeah I have an exhaust leak....trying to get toda rep header but back order lol
Old May 15, 2014 | 09:46 AM
Yes, they are called vacuum pumps
Old May 19, 2014 | 08:43 AM
lambo95
Dec 17, 2006 12:20 PM
whp
Nov 11, 2004 06:35 PM
ZoRG
Jan 13, 2004 02:44 AM
Phat_GSR
Sep 14, 2002 08:31 AM
onyx00
May 23, 2002 06:57 AM
