Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
rear pads not contacting whole rotor
Old May 13, 2014 | 10:06 AM
rgar98's Avatar
10 Year Member
Default rear pads not contacting whole rotor
Hello,
2007 Civic EX (110,00 miles)
I just noticed that the rear outboard pads which are about 1/4 in thick, on both sides of the car, are not making contact with the outer 1/2 in of the rotor. The rotor is shiny except for the outer half-inch, or so. Braking seems normal.
Could it be that the pads are not the correct size? Or, is this normal?
Thanks,
Richard
Old May 19, 2014 | 05:17 PM
Dontoh's Avatar
Default Re: rear pads not contacting whole rotor
rgar98,
This isn't exactly a normal condition, but it isn't due to the wrong sized pads either..
This is typically caused by a worn or poorly lubricated brake component not engaging the pad completely, OR because you have had the rotor OR pad replaced. When doing a brake job, both the rotors and pads need to be replaced together, or it will cause this uneven wear condition.
My best idea would be to replace both your rotor and pad on both sides of the car.
cmyates007
18
Apr 14, 2012 10:19 PM
Romo Pyro
Nov 15, 2010 05:31 PM
tuong
Aug 26, 2004 06:29 AM
Krnbk2
May 28, 2004 12:47 PM
mr tl
Dec 3, 2001 04:31 AM
