help no spark 94 lude h22
H22a obd1put a new harrness in from rywire and hard wired the fuel pump line into the old harness ecu clip like I was told. I got the care to fire and run perfectly! Then my brother decided to pull a prank n pulled the fuel pump wire we wired in out and it killed the car. But instead of it firing once I put the wire in it just turns over and dumps fuel in. No damn spark! Checked all fuses and ground wires appear fine n secure. Any info helps. Thanks
My brother created a spark tester basically sticking a wire in the spark plug wire n tryi g to see it jump to a ground. Tried all 4 plugs got nothin. Not sure if what happened could have fried the tdc or distributor
Unless the sensors in the dizzy tdc i believe is bad. If main relay was bad you wouldn't have fuel. Check the coil and like he stated check the fuses
Gonna replace the dist but I waiting on my cash to come in. Rywire has em for 220 think thats fair or over priced. Also what else should I buy parts wise to just be done with it. No fuses are popped. And with it firing before I cant say it could be the ecu. Not sure tho. Um I tried to get codes from the eng light but its either burnt out or reading 0 which is ecu failure I beleave. Anyways what other parts to be sure other than the dist
When you turn the key forward to ACC II (before turning it over to start) and the dash gauges light up, do you see ECU light ?
Do you hear the click under the dash for the ignition relay?
Rok_Stok
37
Mar 19, 2010 05:34 PM
