Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
What is this thing on the Lower Control Arm
Old May 12, 2014 | 06:01 AM
Pushhands's Avatar
Post What is this thing on the Lower Control Arm
Hey All,
I have a Honda Civic Hybrid that I am replacing the lower control arm on. I have removed most of the bolts connecting it but there is one partthat I do not know what it is. Please see the link below for a box.com link to a picture of it. You can see the thing in the middle of the lower control arm that has 4 little purple buttons on it. I cannot pull out the lower control arm without first getting rid of that thing. You can see the bolt a little lower that is hidden by the lower control arm. That is where the other side of this connects to the lower control arm. I have been trying to remove their nuts but the screw turns with it. I have no room on the other side to put a wrench or anything to keep it still while I remove the nut because this weird purple button cap is on the end. Does anyone have any idea what that is and how I can remove it. Thanks in advance!
https://app.box.com/s/2vy32g700mp2kbm8hlzk
Old May 12, 2014 | 06:54 AM
Pushhands's Avatar
Post Re: What is this thing on the Lower Control Arm
Nevermind all! I figured it out. That is the Sway Bar Linkage. The reason I cannot get the screw off is because I need an alum wrench to hold the thing steady while I unscrew the nut! Man, I wasted hours on that yesterday. Now I know how to proceed! Thanks!
Old May 12, 2014 | 06:59 AM
Almighty-Si's Avatar
Default Re: What is this thing on the Lower Control Arm
To get that off, you put a 5.5mm allen wrench in the center of the threaded part and use a wrench to take the nut off.
mmstadler
Suspension & Brakes
Jun 25, 2013 03:55 AM
decode33
Honda CR-V & Element
Oct 29, 2011 06:48 AM
stevescivic
Jun 21, 2007 07:48 AM
Lee_Delso
10
Dec 31, 2004 09:51 AM
eg2_RE
Apr 1, 2004 05:56 PM
