93 civic coupe No Start....
Hey HT,
I have a civic with a crank and no start problem.
1. Checked main relay - Good
2. Fuel pump and pressure - Good
3. Checked My Coil in the Dizzy and there is a spark(yellow) and spark to my plugs.
4. Assuming the coil works I believe my icm and ecm are working?
5. My timing belt should be fine since everytime I crank the rotor turns..
As I turn the vehicle on it starts to crank and I can hear the motor wants to turn on, but wont .
Planning on removing the head and to check internals.
Would like to know if anyone had similiar problems and solutions..
**Also, prior to this event I was on the freeway going 60-65mph and my car just siezed ever since then it won't start.
Sounds like the timing belt may have skipped some teeth. Take timing covers off, be sure everything is aligned 100%. If so, check tension on the belt. If you still don't have any luck, do a compression test before you decide to pull the head off. Please post the results of the compression test. Is this a usdm motor or jdm?
ddn1313
Aug 4, 2018 02:46 PM
nighttrain33
Mar 23, 2008 01:38 PM
