93 civic coupe No Start....
Hey HT,
I have a civic with a crank and no start problem.
1. Checked main relay - Good
2. Fuel pump and pressure - Good
3. Checked My Coil in the Dizzy and there is a spark(yellow) and spark to my plugs.
4. Assuming the coil works I believe my icm and ecm are working?
5. My timing belt should be fine since everytime I crank the rotor turns..
As I turn the vehicle on it starts to crank and I can hear the motor wants to turn on, but wont .
Planning on removing the head and to check internals.
Would like to know if anyone had similiar problems and solutions..
**Also, prior to this event I was on the freeway going 60-65mph and my car just siezed ever since then it won't start.
Re: 93 civic coupe No Start....
Sounds like the timing belt may have skipped some teeth. Take timing covers off, be sure everything is aligned 100%. If so, check tension on the belt. If you still don't have any luck, do a compression test before you decide to pull the head off. Please post the results of the compression test. Is this a usdm motor or jdm?
ddn1313
08-04-2018 02:46 PM
nighttrain33
03-23-2008 01:38 PM
