Speedometer issue
Old May 11, 2014 | 04:32 PM
Rex-2000's Avatar
Default Speedometer issue
90 hf w/B18A1 sand speedo doesn't work how do I get it up and reading speed again?
Thanks for any help
Old May 11, 2014 | 04:56 PM
br8crumb's Avatar
Default Re: Speedometer issue
unlike the rest of the dash... ur speedo should be a cable. 15-20$ fix and like 30mins
Old Jun 15, 2014 | 11:03 AM
Rex-2000's Avatar
Sorry about the delay I've searched far and wide and cannot find a replacement sensor or cable anywhere and my car doesn't have one currently in it do you know who makes one or where I can find one new?
Old Jun 15, 2014 | 08:07 PM
br8crumb's Avatar
junkyard or ebay would be easiest to buy. and u should be able 2 folo it from the back of dash all the way down. has the speedo ever worked? if so then u have 1 and its prob pulled out. if no then its either broke/removed
Old Jun 16, 2014 | 09:15 AM
BLU CIVIC's Avatar
Track Advocate
this. i have a speedo from my old b18a1 trans that i'll sell you for cheap. but make sure it's the problem first.
Old Jun 16, 2014 | 03:49 PM
Rex-2000's Avatar
I don't have a vehicle speed sensor at all but I'll double check just to be 100% and thank you guys for the help
Old Jun 16, 2014 | 05:55 PM
Former User's Avatar
It's built into the speedometer.
Old Jun 20, 2014 | 07:44 AM
Rex-2000's Avatar
What's the part number? I don't have one at all
Old Jun 20, 2014 | 07:59 AM
4drEF's Avatar
Keyboard Humorist
You are right... sort of.
Your car doesn't have a VSS.
It has a speed pulser.
It looks like this
(Newer cars have a VSS mounted in the transmission.)
This gets mounted in your transmission
And the speedo cable joins the two components together.
Old Jun 21, 2014 | 01:21 PM
Rex-2000's Avatar
Where can I find this? Like parts stores? Online? Or junkyard exclusive?
Old Jun 21, 2014 | 05:04 PM
4drEF's Avatar
Keyboard Humorist
In your car. Unless you point blank don't even have a speedometer
Old Jun 23, 2014 | 06:29 PM
Rex-2000's Avatar
Ok what is the transmission mounted part called?
Old Jun 23, 2014 | 09:46 PM
4drEF's Avatar
Keyboard Humorist
It appears to be called a gear holder assembly.
Is that the part you are missing?
Old Jun 24, 2014 | 04:08 AM
BLU CIVIC's Avatar
Track Advocate
yours should look like the one on the right.
Old Jun 24, 2014 | 07:03 PM
Rex-2000's Avatar
Yes that's what I'm looking for!
hypeRhatch
Sep 15, 2013 10:33 AM
AllMotorLudeSi
Jun 9, 2012 06:24 PM
Channooo
Aug 12, 2009 01:50 PM
Dohc 4door Rye
May 23, 2006 08:14 PM
LAWST
Mar 3, 2005 06:51 PM
