Where Is Backup Light Switch Civic Ef
If I remember correctly you don't plug anything into the transmission, the actual switch threads into the transmission. The connector goes to the harness. The matching connector should be bundled with the O2 sensor connector. Find that and follow it back.
I don't think that's entirely correct then, rather the circular connector to the distributor would be two separate connectors on the DOHC ZC because one sensor is on the end of the exhaust camshaft. I don't recall anything else being different vs a straight up Si with respect to electrical connections.
*This is assuming all is staying pre OBD aka OBD0
89brokendownEF
May 10, 2014 04:48 PM
Shinny
Jun 3, 2012 05:42 PM
neonphire8604
Aug 8, 2006 08:00 PM
