AEM Failsafe Wideband signal out question
I got a AEM Failsafe Wideband and have everything wired up except the output to the ECU. I am running a 97 integra GSR with a OBD1 to OBD2a Conversion harness to a P28 chipped with chrome, my question is this, which wire to I run to the ECU for it to read the signal to adjust to? There are a couple that it could be for datalogging and such however I think I just need one for the signal to the ecu to read. I have read many things and some say one thing others say another but most people are using a s300 or the aem ems.
That's the only way it'll work in Crome. But unless you're using the Gold rom or upgrade to Neptune, you can't run it in closed loop with the failsafe because it doesn't have a simulated narrowband output.
You would wire it up the same way for every chrome.
White - 0-5V signal output.
Brown - You want to connect to a signal ground so the EMS and Failsafe are on the same ground plane.
Alpinestar03
Engine Management and Tuning
Jan 1, 2009 08:54 AM
