Cant find a rebuilt si steering rack
So ive replaced all the inner and outer tie rods, as well as the rack end bushing. I no longer have any play when shaking or tugging on the inner tie rods, but when i rapidly shake the steering wheel back and forth i still hear clunking sounds coming from the rack.
Any thoughts?
the rack did appear to be extremely dry when i inspected it, i feel it may be worn
If i get a replacement rack, should i go new or remanufactured?
http://www.carsteering.com/addtocart...80-70071.html#
also how do i know if im getting an si rack, every new rack claims they fit both, which we know the si is different than the hf/dx.
If anyone knows of who sells rebuilt or new si racks that would be great.
Any thoughts?
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
what is the difference between racks? also if the pump isnt running a clunk is normal when you do that, assuming this is power steering
I would check the steering column u joint on the inside of the car. These wear out and will cause a clunk that seems to be coming from the rack but is just noise transfer. Its right at were the column meets the rack and is very easy to change out.
i re-tightened the rack adjustment and the noise changed slightly but was still very noticeable. the Ujoint appears to be in good condition, it dosnt flex or make noise. if i put my ear to the floor can tell its coming from the opposite side.
Im just going to get a new rack at this point.
Does anyone have any recommendations?
GeoMetry
May 11, 2014 12:24 PM
MulletManRockStar
Jan 16, 2005 01:28 PM
smokey2.0
Feb 16, 2003 06:43 PM
