JUST ANOTHER SIMPLE RWD MID ENGINE SETUP/ SWAP
Old May 9, 2014 | 03:01 PM
honda_mrf22's Avatar
Default RWD MID ENGINE HATCH PROJECT
Setup: 95 eg hatch with f22a6 engine swap. complete stock engine with arp head studs.
Why? Because I love making almost all my torque at less than 4k revs.
-one cam= less rotational mass
-no replacement for displacement
-too much torque steer when i had the engine in the front.
Old May 9, 2014 | 03:04 PM
Default Re: JUST ANOTHER SIMPLE RWD MID ENGINE SETUP/ SWAP
just need to learn how to post pictures.
Old May 9, 2014 | 03:13 PM
Original setup in the front
Old May 9, 2014 | 03:18 PM
NotARaCist's Avatar
I never narc'd on nobody!
So...I'm guessing the mid-engine and RWD part is coming later? Also, you realize the torque steer is caused by the drivetrain, not the engine placement, right?
Old May 9, 2014 | 03:50 PM
turtlegrip's Avatar
Just buy an NSX
Old May 9, 2014 | 07:17 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: JUST ANOTR SIMPLE RWD MID ENGINE SETUP/ SWAP
Driving a civic in reverse doesn't technically make it mid engine and RWD
Old May 9, 2014 | 07:41 PM
StayKrafty's Avatar
I wish there was a like option for comments
Old May 9, 2014 | 09:15 PM
Torque steer is caused by one tire getting more traction than the other. Or power being sent more to one side. Yeah still trying to upload pix onto photobucket from cell then past the link onto this site.
Buy an nsx? Then we all should just drive the same car. We all have different setups. Well me anyways because i like to be different and explore the route less travel.
Yes driving in reverse doesnt make it mid engine but driving in reverse is like driving a mid engine. Floor the car is reverse and it just goes without much traction lost esp in a suoer short gear like reverse.. Thats kind of how a mid engine should feel
Old May 9, 2014 | 09:29 PM
B serious's Avatar
?? So....the car is or isn't mid engine yet?
Old May 9, 2014 | 09:46 PM
hondatech4's Avatar
sweet
Old May 9, 2014 | 10:14 PM
Yeah i heard of scums on ht.
Had my pix all in my other phone but scrern cracked so i guess we will jist fast foward to current time
Damn lots of info missed out on but better than nothing
Dont mind the ugly welding blanket. It was too flexible to work with and the smell from the adhesive spray made me rush it a bit but it will probably be covered with an aluminum sheet or so.
Old May 9, 2014 | 10:24 PM
Spray glued cloth onto the firewall using #90 3m spray. Expensive but good. Guess its a firewall.
Spaghetti anyone? Had to lengthen about 10+ wires that went from underhood fuse both to the ecu.
Old May 9, 2014 | 10:57 PM
Reusing my old and well abused 3" downpipe and adding a few different bends to it
<Br><br>A bit of mocking up and tacking stainless to mild steel. Exhaust gas is going to exit to the right side of bumper because putting it in the oem location wont clear
<Br>
Old May 9, 2014 | 11:22 PM
The finished product. Not the best welding but if it holds thats good enough for me.
Looks like the rear end of a lamborgini or porshe, so i like to think anyways.
Old May 9, 2014 | 11:41 PM
turtlegrip's Avatar
Pretty cool man. Sick set up actually. How do you deal with weight ratios? Being so light in the front and all now, or is it not that bad?
Old May 9, 2014 | 11:45 PM
Shotoutaccord- damn that sucks. I see u had to make a new user. But yeah my other phone had all the pictures but the screen is broken. Ill try to charge it up and see if itll syn with my labtop
Turtlegrip- gas tank up front and a bit of bracing to add weight. Other then that im going to raise my rear end up a bit.
Old May 9, 2014 | 11:55 PM
Here is the cut up front clip i used from my 98 civic. R.i.p. sorry its a tiny pix. Had to screen shot this
Old May 9, 2014 | 11:58 PM
Well see how much better this setup grabs traction. If its noticeably different ill convert my del slow too but instead use a 98 accord front clip since they have oem traction bars, absorb bumps smoother too and a crossmember . Make it a sleeper mid engine. Seems like the del sol was built to be mid engine like the honda beat or FR like the s2k
Old May 10, 2014 | 07:12 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I noticed in one of your last pics, you had the battery sitting on the concrete slab floor....
I'm not sure if you are aware but that kills car batteries dead, like can't recharge dead.
Need to get it up on some wood blocks to prevent damage to the battery.
Old May 10, 2014 | 09:48 AM
Lol i wish i had concrete. Its all osb plywood that i have as my flooring.
Old May 10, 2014 | 09:52 AM
Fabricated some brackets to hold my shift linkage
Then had so make a custom linkage that reverses the push and pull motion to shift into gears. I think this was one of the most painful things about the mid engine swap and using a long geared f22 transmission instead of going f2d
Old May 10, 2014 | 12:59 PM
HondaPartsHero's Avatar
Technical Hero
Not to knock you but that's no longer true. Batteries way back in the day had either rubber or wood casing which if leaked could cause a conductive path to the concrete. Batteries now a days have much more insulation and are incased with material that doesn't allow that to happen, so it's a historical myth that at one time in history was true.
Old May 10, 2014 | 01:25 PM
turtlegrip's Avatar
lmao
That shift linkage is impressive and looks like it took some engineering skills haha. Have you dyno'd the engine? Or have videos of you drifting? heh
Old May 10, 2014 | 10:40 PM
Turtle: not yet but i will post up vids when i decide on buying a water to air intercooler or just reroute my intercooler and pipes. Will post more pix soon
MayorMcCheese
Dec 23, 2011 07:34 AM
luispizarro25
Aug 6, 2008 02:05 PM
imzjustplayin
Jul 5, 2008 04:05 AM
97ek9
May 22, 2006 04:51 AM
Mojo-Jojo
Oct 14, 2002 11:08 AM
