F/S: Built EK Hatch Part Out
Parting out my EK Hatch. Only trades I'm interested in would be for vehicles, and a D-Series Swap. Setup only has 500 miles on it, made 240whp last year on small header/exhaust and cams weren't degreed. Motor work was done @ Green County Machine in Monroe, WI.
Will have the swap out this weekend and get pictures of everything.
815-821-3803 would work best to get a hold of me.
Engine: $2000
-AEBS Sleeved GSR Block
-86mm CP 13.2:1 Pistons
-Eagle Rods
-ACL Bearings
-Stock Crank
-Moroso HD Oil Pan
-Golden Eagle Head Studs
-Hasport Motor Mounts (EK B-Series) - $250
-1000cc Precision Injectors - $200
-S300 - $500
-GSR Cluster with plugs (to wire into civic!) - $75
-Zeitronix ZT-2 Wideband - $200
Head: $SOLD
-Ported GSR Head
-Ferrea Valves-Crower Springs & Retainers
-Skunk2 Pro2 Cams
-Toda Cam Gears
Intake Manifold: $SOLD
-Skunk2 Intake Manifold Port Matched to TB
-70mm Omni Power Throttle Body
-Hondata Intake Manifold Gasket
-Samco Snow Camo Radiator Hoses - $SOLD
-ATI Street Dampener - $SOLD
-BWR Catchcan with Valve Cover & Lines - $SOLD
-99-00 Si Cluster - $SOLD
-OBD2 B-Series VTEC Distributor with NGK wires - $SOLD
-Walbro 255 Inline Fuel Pump - $SOLD
-BDL Fuel Rail - $SOLD
-Full-Race Traction Bar - $SOLD
Video of the car running.
https://www.youtube.com/watch?v=lDb0...ature=youtu.be
Compression test.
cylinder #1
cylinder #2
cylinder #3
cylinder #4
Engine: $2000
-Eagle Rods
-ACL Bearings
-Stock Crank
-Moroso HD Oil Pan
-S300 - $500
Head: $SOLD
-Ported GSR Head
-Skunk2 Pro2 Cams
-Toda Cam Gears
Compression test.
cylinder #1
cylinder #2
cylinder #3
cylinder #4
vtecdamian
Oct 14, 2004 03:55 PM
