Mahle GoldSeries on Stock H22A1 rods
Old May 8, 2014 | 06:09 AM
707the89fu's Avatar
Icon2 Mahle GoldSeries on Stock H22A1 rods
I know I might know the answer
But I would like to verified with people have done it....
H22 Mahle GoldSeries pistons
Can you us them with stock Rods?....
I know stocks are press in and these mahle pistons use a
22mm High quality steel wrist pins
Old May 8, 2014 | 06:38 AM
snobordboy's Avatar
Moderator
Default Re: Mahle GoldSeries on Stock H22A1 rods
H22A1 rods would have to be modified with bushings like the H22A4 rods, but if you are already going to forged pistons, an upgraded rod would probably be a good idea at the same time.
Old May 8, 2014 | 07:00 AM
707the89fu's Avatar
Thank you for your feed back
Old May 8, 2014 | 10:48 AM
707the89fu's Avatar
Also I'm guessing that goes the same as Type-s pistons
Old May 8, 2014 | 05:29 PM
Sparksman's Avatar
^ yep need to modify a A1 rod for them as well.
Old Aug 29, 2014 | 06:30 PM
707the89fu's Avatar
thank you!!
Project_SOHC_EX
Dec 19, 2009 11:58 AM
turbo-crx
Apr 18, 2008 09:08 AM
specie
Mar 7, 2004 01:51 PM
98civicEX
Aug 19, 2002 02:58 AM
fastludeh22
Aug 13, 2002 07:00 AM
