tb trick
Old Oct 30, 2002 | 09:41 AM
Ideal's Avatar
Default tb trick
What is this thing about tightening it and getting a bit more horsepower? How do i do this if it is possible, my car is in my sig, stock.
-Jon
Old Oct 30, 2002 | 10:55 AM
Ideal's Avatar
Default Re: tb trick (Ideal)
Tigtening it so that it allows somethign to happen faster or something, anyone?
-Jon
Old Oct 30, 2002 | 11:00 AM
gringo7718's Avatar
i think you are trying to describe taking all the slack out of the throttle cable so it opens sooner with little pedal effort. also be sure when pedal is floored the tb is opened up all the way. its not a trick and it wont MAKE any power, just improved throttle response
Old Oct 30, 2002 | 11:05 AM
Ideal's Avatar
Default Re: tb trick (gringo7718)
So how would I go about doing this?
So it doesnt make any power, but improves response time beetween you pushing on your pedal and accelerating, is that what I am understanding?
I am Automatic, just incase it doesnt apply, but I highly doubt that.
And to take out the slack, what do I do, and to make sure it opens all the way when i floor it, what do i do? If it isnt?
-Jon
Old Oct 30, 2002 | 11:51 AM
iam7head's Avatar
no it wont make any extra power but it allow you get access power faster.
Old Oct 30, 2002 | 12:06 PM
iam7head's Avatar
Default Re: tb trick (iam7head)
you need someone to press the gas padel for you so you wouldnt mess up
the cuiuse control cable.
Old Oct 30, 2002 | 07:31 PM
Ideal's Avatar
im not to shure what the cable looks like, but, so with the car on, in park, he pushes the gas all the way? then you just tie it or something to remove the slack?
-Jon
Old Oct 30, 2002 | 08:38 PM
Nick M's Avatar
-Jon
Good God almighty...
Attempting what you are describing is only going to cause a problem in my opinion. If you want better throttle response, get a large J's style intake, a bigger TB, new IM etc.
Messing around like you describe especially with something that can be a PIA like a throttle cable is just asking for trouble.
Old Oct 31, 2002 | 03:28 AM
TouringAccord's Avatar
H-T Order of Merit
A friend and I did this to mine a few months ago. You are able to feel a little difference (not in HP but in how much quicker the engine reacts to you pushing the petal). If your unsure you should have someone else do it so you don't take out to much slack. Someone else in another forum did this to there Accord and they said they're idle jumped to 2,500 RPM.
Old Oct 31, 2002 | 07:02 AM
smokin rubber's Avatar
Default Re: tb trick (Nick M)
make sure the car is not on when you floor the pedal
just feel the cable that attaches to the throttle body, if there is slack in the line take it out.
Old Oct 31, 2002 | 08:09 PM
Mr Ben's Avatar
Default Re: tb trick (smokin rubber)
This does help. I have 92 Accord Auto. If it is not tightened enough it is possible your throttle plate never fully opens. Also on autos, the cable bracket also attaches to the auto tranny speed cable, so it shifts better. I think you just need a 10mm wrench and there are 2 nuts on the cable to adjust.
Old Nov 1, 2002 | 02:35 PM
SlowLow5thGen's Avatar
-Jon
OMFG LOL I'd Like To Have A Camera There When You Were Doing That.. Just To See Which Happens 1st, The Engine Blow, You Go Def, Or Some Kinda Clothing Catch's In The Belt Assembly
But No, Messing W/ The Throttle Body Cable Does Help W/ Response, But Be Warned Once You **** With It Once It Will Need Constant Adjusting, I Did Mine On My Old 91 Auto, And It Was Helpfull, But For Some Reason It Would Come Loose After Time, Even Though I Tightened The **** Outta It.
Old Nov 1, 2002 | 02:56 PM
iam7head's Avatar
Default Re: tb trick (SlowLow5thGen)
once you fu-k with it you need to what?
just tight it back..
helpful? not that great i hope
Old Nov 1, 2002 | 07:17 PM
Brandon's Avatar
Life is Suffering
Really, if the throttle cable has too much slack in it, you should just replace it. There is no point in adjusting it if it will just stretch more and more now that it is old.
JDMCIVIC919
Feb 20, 2012 10:48 AM
notstock93
Sep 1, 2004 09:20 PM
mazzy
Honda Motorcycles
Aug 20, 2004 12:01 AM
pho king guy
Dec 14, 2001 08:50 PM
