Honda CR-V & Element 2WD & 4WD Element & CR-V
alignment question (also need rear struts)
Old May 6, 2014 | 12:11 AM
ginahoy's Avatar
10 Year Member
Default alignment question (also need rear struts)
Does replacing rear struts affect alignment, assuming the tech knows what he's doing? Here's why I ask...
One of the rear struts on the wife's 2006 CR-V (44k miles) is coated with road grime (it looks very different from the others), indicating a leak. The ride is still fine, and nothing showing up on the garage floor, so I plan to put this off for a while. However, I just drove the car on a trip and noticed it pulls to the right.
I'm concerned that if I have the car aligned now, and then replace the struts later this year, it might throw the car back out of alignment. On the other hand, I prefer to go ahead with the alignment right away to protect tires, but I don't want to have to pay to have it done again after I do the struts.
Advice would be appreciated.
Old May 6, 2014 | 09:15 AM
kiseliok's Avatar
Default Re: alignment question (also need rear struts)
If you replace it with the same stock strut, it should have no effect on your alignment.
Old May 6, 2014 | 02:09 PM
ginahoy's Avatar
10 Year Member
Great point. I should have mentioned I plan to install Monroe OESpectrum. It's supposed to be a direct replacement, so I guess my question is whether this particular strut (on rear) would affect alignment.
Old May 6, 2014 | 02:59 PM
94EG8's Avatar
Seagull Management
It wont affect the alignment, but those Monroe shocks aren't much good. You're a lot better off going with a KYB GR-2/Excel-G. Tokico blues aren't bad either but tend to be a little stiffer than stock. To be totally honest I'm surprised it needs a shock at 44,000 miles, the OEM Showa shocks will normally go a long time, It's not usual to get 200,000 miles out of a Showa shock and I've seen some go to 250,000 and not be blown.
Old May 6, 2014 | 06:07 PM
ginahoy's Avatar
10 Year Member
Originally Posted by 94EG8
To be totally honest I'm surprised it needs a shock at 44,000 miles...
Yeah, exactly my thought. Can you or someone else confirm the diagnosis? Last time I had oil change, the inspection report indicated "rear shocks leaking" along with price for replacing all four (no surprise). I got a quote for just doing the rears.
Since there's no evidence of fluid on the garage floor, I grabbed my shop light and looked for myself. The two fronts and right-rear shocks were a bit dusty but black cylinders and logo markings are clearly visible. If I wipe with a dry rag they look pretty much new. But the left-rear is nasty looking; the cylinder is coated with road grime. A dry rag doesn't do much except make the rag dirty. I assume this is a smoking gun for a bad shock, right?
BTW, given the low mileage on the vehicle, I asked the shop about replacing just the one. They recommended against that. But given what you said about OEM shocks typically lasting *much* longer, I'm thinking I'll just have the bad one replaced. I doubt we'll keep the car longer than 4 or 5 more years, so at 6k miles/yr, it's unlikely to see much more than 70k total before we sell it. What do you think?
Old May 7, 2014 | 08:26 AM
kiseliok's Avatar
Did you check other components around that area? Axle boot? Maybe something else is leaking?
When I blew my struts, I had oil pouring everywhere - there was definitely a lot of liquid and would be impossible to not notice.
Old May 7, 2014 | 02:13 PM
ginahoy's Avatar
10 Year Member
Nothing obvious. I guess I should use some solvent to clean the area so I can verify the source.
ribal_gh
Suspension & Brakes
Mar 15, 2013 01:21 AM
-iLLuZioN-B18C1
Suspension & Brakes
Feb 1, 2010 04:24 PM
JDM illmatic
Suspension & Brakes
Nov 10, 2008 04:51 PM
OoHiTzToMMy
13
May 25, 2004 07:41 AM
miedosoracing
Apr 6, 2004 03:06 PM
