Changing out springs on coilovers.
Here's the deal. I got GC's for a 01 GSR. The springs that they sent me aren't the compression I want. I would like to have 400f/350-375r. So do you think I could call GC and say hey would you guys give me a discount on some springs with the compression mentioned above if I sent you my spring I orginally got with my GC's from another vender.
Also with the stiffer compression I'm assuming that I could still go for the ride height that I'm currently at.
front
rear
Coilover setup
front
rear
Coilover setup
I don't get it. I just ordered some Ground Controls and I called them directly. I said "I'd like to order some of the coilovers for a '73 Celica." We talked a little about my intended use (track and autocross, not daily driven). And I got a suggestion of the exact rate I was planning to order, 350 lbs. I had a choice between 7" and 8" springs, so I mentioned the possiblity of rally cross, and the 8" springs became the best choice.
For the cost of a long distance phone call I got exactly what I wanted, and it didn't cost a penny more than the regular price.
So, how did you get the wrong spring rates?
Finally, to answer your question... No, they won't give you trade in on the springs, however you can probably sell yours one of many places on-line and get $30-50 for a pair (about half of what new ones cost).
Scott
[Modified by celica73, 6:37 PM 10/30/2002]
Scott
I have no idea on what rates I have now. Those little numbers don't tell me ****. Anyways That's probably what I'll end up doing, selling the ones I have now and getting the springs rates I want from GC or some other vendor.
BTW I didn't order them from GC.
wait a minute, youre worried about getting at the same height with another set of springs? dude, you have ADJUSTABLE spring perch, you can get at whatever reasonable height you want, nearly independent of spring rate.
Follow?
Nope. The car still weighs the same. Regardless of ride height, the springs will be loaded the same, as the car weighs the same.
I'm getting educated or OWNED.
<---- hates that term.
The spring doesn't get compressed any more by changing the ride height.
The only way to change the spring rate (stiffness) is to change the spring.
