Coolant holding pressure after its cooled down...
I know this seems like a newb question, but in my years, i have never personally dealt with this situation. As the car heats up, it builds what seems like excessive pressure. Squeezing the upper and lower hoses, they get hard. Which i know is normal. Everything is normal, car runs fine, doesnt smoke, doesnt use coolant, doesnt over heat. There is no mixing of coil/coolant. But i noticed last night after the car was completely cooled down, like 12 hours after it was running, there was still pressure. I pulled the radiator cap and it was a big release of pressure. Not sure what would cause that. Everything i read said it was a head gasket issue but being a head gasket issue, i would think it would be going through coolant or something...over heating....something lol. Only issue is its holding pressure for a long period of time. So...any insight?
Its a golden eagle sleeved block, 84mm, 8.5:1, B16 head, Honda head gasket.
Its got a new thermostat and the cap hasnt been replaced recently. But the spring in the cap and plug seem to be fairly easy to push so im not sure why it wouldnt be pushing the cap open.
And its got an eBay aluminum radiator in it so an OEM cap wont fit. Im gonna have to go to the parts store to find a cap.
And still doesnt make sense why it will hold pressure overnight or longer.
for what its worth, a customers car with an ebay radiator was doing the same thing and found that the cap was getting stuck on the neck of the radiator and not allowing the spring in the cap to compress
I think it may be a blown head gasket unfortunately. When its cold it builds pressure almost instantly and coolant has been heating up alot quicker.
So i went a got a new cap. Drained all the coolant out and put water in it since thats whats supposed to be in it at the track. Noticed that its not building pressure like it was before, but i am noticing that with the cap off, its got quite a few bubbles coming up...at first it was bigger bubbles, now its little tiny ones and seems like its producing less and less. Just not sure when i completely drained the coolant and blew air in and flushed every bit out, how much air will be coming up. I let it run for about 30 minutes.
Had a buddy put gsr head studs in a b16 years ago and it did the same thing your explaining, car never over heated just built UN normally high pressure and never released
once again if you think it is a blow head gasket do a chemical block test
http://www.napaonline.com/Catalog/Ca...006_0361073538
It was a leaking gasket. The gasket was a cheap one from auto-zone thats over a year old ona car making over 700hp.
Cause i normally use Fel-Pro gaskets. And the day i pulled the head off, i couldnt find one locally for a decent price. I wasnt going to spend $150 on a head gasket. The only one i could find was the no name one at AutoZone. I want the car to get back out to the track the next day so i used the no name one. And almost a year later, it finally failed. So im not bitching.
Head gasket is the result....not the cause. You likely lifted the head from detonation, weak head studs, or bouncing hard off the rev limiter or something. The head lifts and scorches the gasket, lets coolant past and there you have your pressure issue.
Replacing the gasket may only be a temperary fix if one of the above are present.
i run the 81mm gaskets since im still on stock bore,i just borke a gasket testing out some crazy timing at the track since my gate springs wouldn't allow anymore than 34 psi and 147 mph was too slow.
anyways i think these perma torque gaskets may not be the best but they fail almost instantly when something goes wrong.ive been on the same head and rotating assy for 3 years but ive been threw some head gaskets. i just think of it as a fuse. i replace it ever now and then.
Kadams587
Aug 16, 2018 04:04 PM
RollTide
Honda Civic (2001 - 2005)
10
Jun 1, 2012 01:25 PM
