Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2007 Pillot - A/C compressor clutch not engaging
Old May 3, 2014 | 11:19 AM
Slow-n-Steady's Avatar
Icon2 2007 Pillot - A/C compressor clutch not engaging
First post - WooHoo!
Hello - 2007 Pilot. A/C Compressor clutch does not engage. Coolant was low but added to appropriate level. Clutch still does not engage. Blower motor runs and blows ambient temperature air as expected. Fuses/Relays swapped with others of same value/type with no difference. Both radiator fans are running. Engine RPM increases slightly when the A/C is turned on.
My power steering rack and pinion was replaced over the winter. This is the first time I've checked the A/C since the repair. Even though they are in different areas of the engine, is it possible the mechanic did not reassemble everything properly? I know how to use a meter if I need to check voltages. Thanks - Slow-n-Steady.
Old May 4, 2014 | 12:57 PM
Jjbaehr's Avatar
Check for battery voltage at the coil with engine running and A/C on, if you have voltage your problem is within the coil.
Old May 4, 2014 | 03:42 PM
Default Re: 2007 Pillot - A/C compressor clutch not engaging
Thanks Jjbaehr - I'll look into it.
Old May 9, 2014 | 08:00 PM
Torres123's Avatar
the compressor clutch won't engage if their isn't proper level of freon in the system. you can do a simple test to see if their is enough freon in the system though. find your low pressure switch in the system and from my knowledge its located on the accumulator. disconnect the switch and check if its a two wire low pressure switch and take a jumper wire or for simple test you can use a paper clip. jump these two wires on the low pressure switch and if the compressor kicks on then you have low freon in your system and need an Evac/Recharge of your AC System.
Old May 24, 2014 | 11:18 PM
jmaze's Avatar
check your ground to the a/c relay if there is one like my civic has running along the passenger side harness
Old Jun 21, 2014 | 05:21 PM
ChadB's Avatar
The clutch relays tend Togo bad. The CRX RDX Pillot all had a recall from Honda.
CrossCountry
19
Jul 7, 2016 06:03 AM
boldtu
Aug 18, 2015 09:56 AM
gootch
Honda Civic (2001 - 2005)
Mar 15, 2014 04:03 AM
Uncle Ben's
12
Aug 22, 2012 10:42 PM
SOHC4life 96
Jun 1, 2004 01:47 PM
