Is it possible to run forged floating pin pistons on stock press pin rod?
Old May 3, 2014 | 08:31 AM
stinkbox's Avatar
Default Is it possible to run forged floating pin pistons on stock press pin rod?
I've heard that its possible and I've also heard it would be fine to use the stock pressed pin in the forged piston with the stock rods? This sounds like a failure waiting to happen to me though. I feel you should use what it was originally designed to be used with but am curious if it is possible or even ok to do. Would it be reliable? No pin seizure or loose tolerances ect?
Old May 4, 2014 | 10:49 PM
SpokaneSpeed's Avatar
Default Re: Is it possible to run forged floating pin pistons on stock press pin rod?
Definitely not. They need to be matched. Also - why are you running stock rods with forged pistons? If you're spending the money for forged pistons, why are you skimping by reusing the stock rods?? They will no doubt be your weakest link. Spend the money and upgrade your rods.
JDMstormtrooper
Mar 1, 2012 07:14 PM
ShawnR
Jan 5, 2006 03:35 PM
RACING INTEGRATION
Jun 2, 2005 12:22 PM
blazin
Oct 10, 2002 01:33 PM
KRiS1
Jul 29, 2002 01:56 PM
