Need Help! looking to buy an ITR
Old May 1, 2014 | 04:26 AM
20vsleeper's Avatar
Default Need Help! looking to buy an ITR
Good day everyone,
Need your expertise; I am looking to purchase a ITR, preferably all stock and all original. What I am looking to know is how to identify if everything is "matching" and what else should I be looking for.
I am located in Canada, not sure if that makes a difference.
1. How do I match VIN's (engine to chassis), What else should I be looking for when trying to "match" everything to be all original.
2. What are other key items I should be looking for when viewing the car
Thanks for your help and advice!
Old May 1, 2014 | 05:59 AM
Ely2.45's Avatar
Default Re: Need Help! looking to buy an ITR
There will be a vin on the Trans,block(kinda hard to see),hood,fenders,trunk,doors,front bumper.make sure it matches the one on the title(all of them) and that the miles/km match as well
Old May 1, 2014 | 08:28 AM
98ITRAgain's Avatar
VIN in stamped into the firewall above the fuel filter and the tag on the dash. These two must match, and all the above mentioned parts must match the VIN too. That is if you want a totally original R.
Gonna be expensive so be prepared.
Old May 1, 2014 | 09:09 AM
20vsleeper's Avatar
Thanks for the feedback...
just to clarify the VIN on the trans and engine, they are not the seriel numbers correct? eg. B18C5xxxx or S80xxxxx... I should be looking for the actual VIN's.
Where would they be located?
Old May 1, 2014 | 09:50 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
If you're looking to get into a R, you should take a look at this site. It will answer many of your questions.
http://www.integratyper.org/links.htm
Give it a good read
Old May 1, 2014 | 02:10 PM
safedriver's Avatar
What to shop for, when looking for an ITR, hmmm....
An enclosed garage
Old May 1, 2014 | 02:33 PM
Ely2.45's Avatar
The vin on the Trans and block will match the vin on the firewall and the tag on the dash
Old May 2, 2014 | 03:31 AM
20vsleeper's Avatar
Where is the VIN on the block?
Old May 2, 2014 | 05:27 AM
Punkaddic's Avatar
front bottom
carlosjdmcivic
Jan 31, 2012 05:05 PM
HondaKid99
Oct 29, 2006 07:21 PM
I Eat Glue
Texas -OK -LA (Sales)
Sep 14, 2005 07:27 AM
