Catalytic Converter problems
Old Apr 30, 2014 | 10:53 PM
Uljima's Avatar
Default Catalytic Converter problems
Hi I just got back from getting my car smogged and it failed! The guy told he that there was something wrong with my catalytic converter. I plan on getting a new one. I have a b18b1 swap on a 2000 ek. I was looking at some off the magnaflows which one do I get, the one that is for my car a civic 1.6L cata or will I get a 1.8L cat that is from an integra that is appropriated for the b18b.
Old Apr 30, 2014 | 11:10 PM
turbomaniac's Avatar
Default Re: Catalytic Converter problems
before replacing your cat make sure that this is realy your problem. Do yoy have an OBD code?
use a special instrument to mesure exhaust gas pressure (it is positionned at o2 sensor's place)
high pressure must be a sign of damaged cat or damage exhaust box.
Old May 1, 2014 | 12:06 AM
Uljima's Avatar
P0420 came up the catalyst is accually very old I say I prob have had 220k miles on it. I also tried cleaning it but didn't work.
Old May 1, 2014 | 02:06 AM
yes at 220k miles every cat must be replaced...
Old May 1, 2014 | 06:13 AM
Uljima's Avatar
So which one do I get?
Old May 1, 2014 | 11:05 PM
magna flow for b18
Old May 2, 2014 | 05:34 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
An easier way to see if it is working is to use an infrared temp gun and make sure the outlet is hotter then the inlet or at worst the same temperature. If it is colder at the outlet you have a bad catalytic converter.
CO671
Sep 1, 2012 08:04 PM
mrspeedy69
15
Jun 13, 2009 06:09 PM
k_lude
Feb 22, 2007 09:33 PM
ITSUKA
Aug 4, 2004 09:03 PM
AirWaveGT
Mar 26, 2004 09:42 AM
