Need help with this leak
Old Apr 30, 2014 | 03:07 PM
bluelights81's Avatar
Default Need help with this leak
2000 Accord EX, F23A4, manual. Just replaced the valve cover gasket, and just got the parts today for the distributor o-ring and also the gaskets in the VTEC solenoid which I'll be doing within the next couple of days. Am trying to chase this leak, as pointed out in the two attached pictures. I can't notice it when the engine is hot and running, only after I shut it off. Doesn't coat the whole area, but as you can see, it's obviously coming from somewhere. Do you think the it's being caused by the above parts that I'm about to replace? Need help. Thanks!
Old Apr 30, 2014 | 03:28 PM
holmesnmanny's Avatar
Yes prolly distributor oring will fix that.
Old Apr 30, 2014 | 06:00 PM
djkurious's Avatar
Default Re: Need help with this leak
http://www.autozone.com/autozone/par..._673386_11542_
Old May 1, 2014 | 04:44 PM
hope so, got scared seeing as that's the area of the head gasket. Thanks guys!
ttmix
Jul 30, 2012 06:53 PM
lv6l
14
Mar 8, 2009 11:14 AM
jshonda
Nov 10, 2006 03:13 PM
fujiwara takumi
Jul 29, 2006 12:26 PM
RTW DC2R
Sep 25, 2002 08:05 AM
