1992 CX Honda Hatch w/ B20B swap Idle Issue
Old Apr 30, 2014 | 09:15 AM
Tim_EG's Avatar
Default 1992 CX Honda Hatch w/ B20B swap Idle Issue
Ok whats up hondatech ive been experiencing a idle issue with my 1992 Honda civic cx with an ls swap i changed the iac sensor and computer and that did not solve the issue then ive changed all the hoses on the motor anti freeze level was good oil level was good everything was good so then i found a buyer for my ls and sold it then bought a b20b from jdmengineworld in queens and i also put in a gsr transmission i changed all the hoses on the engine before i put it in got everything in there and i am still having the same idle issue i did with the ls what hell can the problem be i thought when i put the new engine everything was going to be good hence the reason why i sold the ls i also changed the engine harness when i put the new b20b in all anti freeze level is good oil is good new computer again i don't know whats going on what can it be
Old Apr 30, 2014 | 05:46 PM
Tim_EG's Avatar
Default Re: 1992 CX Honda Hatch Idle Issue
147 views no 1 knows whats up?
Old Apr 30, 2014 | 05:47 PM
Tim_EG's Avatar
i dont want to have to sell the car
Old Apr 30, 2014 | 06:56 PM
digitalvice's Avatar
What ecu did you use? Was it chipped? Has it been tuned?
Old May 1, 2014 | 04:13 AM
Tim_EG's Avatar
I'm running the same ecu my friend had in his b20 del sol not chipped not tuned it's a bone stock motor
Old May 1, 2014 | 07:12 AM
24TEN's Avatar
PHANTOM MENACE
Can you elaborate on the idle "issue" that you're experiencing?
Old May 1, 2014 | 08:13 AM
Tim_EG's Avatar
On both the motors the first 10-15 seconds of start up car idles normal then after that it just starts bogging up and down like from 1k-3k
Old May 1, 2014 | 08:26 AM
24TEN's Avatar
PHANTOM MENACE
Rapidly? Or gradually?
Old May 1, 2014 | 08:27 AM
MartyZ's Avatar
You check the o2 sensors? When you first start a car while it's in open loop it's reading off engine sensors while the o2 sensors warm up to work properly. Once the car starts to warm up the o2 sensors kick in. Atleast that's my understanding and if I'm wrong, someone please correct me. So if it's fine when you first start but not after. Could be that.
Only thing I can think of that would remain the same in the car that affects performance after a complete engine swap. Other than clogged fuel filter / lines / or faulty fuel pump.
Dasfinc
Jun 19, 2008 03:53 PM
civichatch2429
Nov 29, 2004 10:22 PM
Race Egr
Apr 3, 2004 02:20 PM
frankenEG6
May 11, 2003 09:47 PM
civicrtype
17
Oct 23, 2002 01:47 PM
