Oem radio question
Old Apr 29, 2014 | 06:31 PM
Bluebeautycrx91's Avatar
Default Oem radio question
So I'm putting in the oem radio in my 91 hatch tomorrow and it has a aftermarket one in it now. So my question is will the plug in work with the oem ive never replaced a radio before fast Info would be greatly appreciated thanks.
Old Apr 29, 2014 | 07:04 PM
mike205's Avatar
Default Re: Oem radio question
You should be ok as long as whoever put the aftermarket radio in didn't cut the factory harness.
If your asking if the plug on the back of the aftermarket radio will work in your factory one no it wont
Old Apr 29, 2014 | 07:20 PM
I took a quick look under the dash I don't remember any cut wires but would a aftermarket radio have a harness that would plug into the original then swap at the other side for the new radio? If that makes since
Old Apr 29, 2014 | 08:18 PM
codybuRr's Avatar
sometimes aftermarket kits come with adapters and maybe that was used.
Otherwise you might have to solder on the OEM connector.
Old Apr 29, 2014 | 09:08 PM
Ok Sousa good thanks for the info I will see how it looks tomorrow
Old Apr 29, 2014 | 10:04 PM
4drEF's Avatar
Keyboard Humorist
Are you sure you want to take that step backwards and install the OEM unit? Any recent cheap aftermarket is better than the ancient stock one.
Old Apr 30, 2014 | 04:28 AM
bheinen74's Avatar
problem is, anything aftermarked is a theft item; a reason for a broken window in your future. also a reason you will have a smashed center console and your climate control panel will be broekn to bits too when they pry your aftermarket out with a screwdriver.
A oem, is not going to be theft item, especially a casette with am/fm only.
Also, a old junky broken looking one, OEM, that works is the best to deter theft.
what 4dr ef says, is exaclty the point I just said about any aftermarket is a theft item, whereas, like he says, nobody would want a oem.
kids steal the sony's alpines, panasonic, kenwood, pioneer etc only (back in the day even a KRACO was a theft item over oem). they don't steal oem.
Old Apr 30, 2014 | 06:22 AM
The only reason I want to put the oem radio in I sim putting the car to the original state that the car came in. Just like off the showroom floor. Plus the car is in storage and only comes out on nice days.
Old Apr 30, 2014 | 07:39 AM
4drEF's Avatar
Keyboard Humorist
bheinen74, if you are driving an 88~91 and simply worried abut the radio disappearing, then I have a surprise for you. The entire car is more likely to disappear than an $80 radio... unless you like in a crack-head district.
Old Apr 30, 2014 | 03:36 PM
smilindave's Avatar
Like me, fortunately my spouse is a crack shot and the cameras and security lights are really good deterrents. Good luck with the install. Also if the aftermarket was installed by someone good, the radio will be secured under the dash from the rear, thats what I did.
Regards
Dave
Old Apr 30, 2014 | 03:45 PM
Yes it was installed good had a bracket holding the rear in ans the pictures are in my build thread Thanks for the help and info guys
PeterVSays
Mar 29, 2013 06:16 PM
93CX
Audio / Security / Video
Jan 31, 2012 11:23 AM
quirarte626
Nov 2, 2009 11:07 AM
SiREJ8
Sep 3, 2007 07:19 PM
ctam1986
Jun 28, 2007 07:59 AM
