B16b on chrome
Old Apr 29, 2014 | 03:01 PM
vmolla1's Avatar
Default B16b on chrome
Ok I have a b16b LSD trans... I have installed bolt ons...
Like header
2.5 exhaust
Head work
New timing belt water pump tensioner
Ect...
My question is I plan on getting tuned just tryin to have something simple for this summer like around 210-220 hp...
Ik everyone is gonna suggest hondata s300 but wat are some reviews on chrome...
Old Apr 29, 2014 | 03:25 PM
JoeBlue's Avatar
Default Re: B16b on chrome
210 WHP on a stock B16b..... LOL, not gonna happen.
Old Apr 29, 2014 | 03:32 PM
vmolla1's Avatar
Who ever said it was stock... Just wondering if crome is a good route???
Old Apr 29, 2014 | 04:01 PM
JoeBlue's Avatar
If I spent $3-4K on the swap and then wasted the money to open up the B16b stamped 'GSR' block to install aftermarket items just to have that B16b stamp and then thought tuning it on Crome after burning all of that money was a good idea, I would feel like a tool asking if it would work.
If you can afford a B16b, you can afford Hondata or NepTune. If you can't afford either of those two, then why do you have a B16b block, and what would make you think opening up an already finely tuned engine accomplished you?
You are not hitting 210WHP with a B16b under 10K RPMs and without at least 13:1 compression. This means not streetable due to the fuel being used being nearly $10 a gallon, or relying heavily on E85.
Go ahead and throw your several thousand dollar build under Crome, just don't blame anyone else when it blows up.
Wish this obsession with Type R would die off. 15 years and it's Type-R this and Type-R that. Enough already, those guys making those sub-10 second passes are not using Type-R blocks. The fastest road racing cars are not using Type-R blocks. Why does every ricer want to use a Type-R block?
Old Apr 29, 2014 | 04:05 PM
vmolla1's Avatar
Thanks for info
Old Apr 29, 2014 | 05:32 PM
soaringchimp's Avatar
B16 with no change in compression, chrome will get the job done.
I would be surprised if you break the 190whp mark.
Old Apr 29, 2014 | 06:15 PM
UncleD's Avatar
I would go with whatever your tuner is most comfortable with. A specific program won't do you any good if your tuner doesn't have the softwear to use it.
Outside of that - I personally would do Neptune. I know people were having allot of problems with Chrome, the issue may or may not have been resolved yet.
Talk with tuner, do what they recommend. If door is open, I would suggest Neptune.
Old Apr 30, 2014 | 04:50 AM
whitesihatch's Avatar
Neptune is cheap and can do everything that hondata can do.
gixxerboy750
Engine Management and Tuning
16
Jan 25, 2010 09:23 AM
sinister357
21
Oct 29, 2004 10:31 AM
eddiecut
Mar 19, 2004 08:18 AM
Vampyre
Apr 10, 2003 12:17 PM
rb'sbsg
May 10, 2002 05:29 AM
