camber
Hi just wanted some advice I took my teg for a adjustment the other day and Ive got 1.2 camber on the left and 2.7 on the right anyone had a simular issue ive got standard shocks springs the lot and cant see any signs of any accident damage, any thoughts
That sounds similar to my current scenario. I hit a pothole (on track) at speed and it immediately tweaked the front right knuckle. I replaced the front LCA's first since I needed new bushings, but the issue persisted. I havae purchased a new knuckle, bearing, and lower balljoint to replace that corner.
My scenario:
LF: -.86deg
RF: -2.87deg
My scenario:
LF: -.86deg
RF: -2.87deg
Im gonna rip it apart I think and check it out bit will be annoying if I have to change the lca 2 months ago I replaced all the bushes for performance spec so have to do it all again lol the joys
Cool Cool Island Breezes. BOY-EE
If those bushings aren't well made or incorrectly installed, you could have some camber change from those. What kind of bushings?
they're energy suspension bushes in other words polyurethane race hardened bushes i dont think its the bushes though it was the same before i had the bushes changed but the old ones were in a bad way i was hoping that was going to sort it but unfortunately not
Polyurethane bushings change a lot of angles inadvertantly. They're also going to wear out in about 2 years. Not hatin...just saying.
But you may be right about your spindle issue also.
If a hub were bent, you'd be getting a wheel wobble because the hub rotates. Spindles can bend and you'd just have an alignment angle off.
Caveman74
17
Feb 21, 2004 09:32 AM
