Exhaust Question
Old Apr 28, 2014 | 06:26 AM
CorbinMB's Avatar
Default Exhaust Question
Is there a difference between an EX model and a LX model with the exhaust? I have a 97 LX Sedan and after all my research they all say the headers are different. So would i need to install an EX header? Not sure if it would bolt up to my D16y7 header. Or will everything bolt right up? Any modifications?
I've never dealt with a full exhaust before.
Here is the exhaust I want to get...
http://www.procivic.com/pages-produc...968/index.html
Old Apr 28, 2014 | 06:41 AM
Wahski's Avatar
Default Re: Exhaust Question
Big difference. The LX cat is located in the header vs. under the car on the EX model. To make an EX exhaust compatible you'd have to get an EX specific cat and header and reroute the O2 sensors.
Disclaimer: I have no personal experience with this setup I'm just going by what I've read over the years.
Old Apr 28, 2014 | 06:48 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
EX/Si:
Manifold > downpipe > cat > B pipe > axle back/muffler.
Others (96-00):
Manifold/Cat assembly > long *** B pipe with downpipe integrated > axleback/muffler.
To use a EX exhaust, you need a header or manifold and downpipe from an EX, a EX/Si cat, and a EX/Si B pipe.
Basically you need everything from the manifold to the axle back to be 96-00 EX sedan. Then extend the secondary O2 sensor wires about 3-4 ft.
Old Apr 29, 2014 | 06:31 AM
CorbinMB's Avatar
Thanks for the info. But will the EX/Si parts bolt right up to my LX?
Old Apr 29, 2014 | 02:19 PM
B serious's Avatar
Ex manifold and downpipe.
EX/si cat.
EX/Si B pipe.
Those will bolt on. But you have to buy ALL of it.
Then extend the secondary O2 wire. Do that on the harness side unless you're a magician and can solder stainless steel on the O2 sensor side.
ozh_hawaiian
Feb 9, 2026 07:04 AM
Valenzuela
Honda Civic (2001 - 2005)
11
Aug 25, 2006 06:46 PM
illdstu
Apr 26, 2004 09:14 AM
Nsane1
Apr 10, 2004 08:54 PM
2000blackgsr
Apr 15, 2003 07:53 PM
