I have a little miss
Old Apr 27, 2014 | 05:44 AM
goat86's Avatar
Default I have a little miss
Just got everything done on my crx but if your goin down the road cruzin and your just barely on the gas it has a little miss if you give it more gas it goes away does any one no what causes this and it idles higher than it should ive tryd everything still does it cud it be a throttle position control sensor help me
Old Apr 27, 2014 | 05:52 AM
EFvtec Yo!'s Avatar
Default Re: I have a little miss
Is the check engine light on?
Old Apr 27, 2014 | 09:49 AM
ef2_civic's Avatar
No wouldn't be ur tps. Sounds more like a ignition timing issue or even fuel pressure
Old Apr 27, 2014 | 08:35 PM
goat86's Avatar
Icon5 Re: I have a little miss
Check engine light comes on after its warmed up. And I no the its not the timing. It doesn't do it as bad when its warm its worse when you start
Old Apr 28, 2014 | 11:30 AM
instrument's Avatar
What is your cel for, I would probably resolve it and see if issue persists.
Old Apr 28, 2014 | 04:34 PM
bheinen74's Avatar
tps sensor.
asnboi512
36
Aug 22, 2013 05:34 PM
mcnos
Dec 18, 2011 11:53 AM
thegod
Aug 9, 2008 07:27 PM
mlsmith95gsr
Aug 22, 2005 10:15 AM
aphex23
14
May 18, 2005 11:41 AM
