B20v in eg
Old Apr 25, 2014 | 03:34 PM
KidDxbOrI's Avatar
Default B20v in eg
Want to swap b20b block and b16 head but I don't know what harness to use or what computer to use , people saying I have to use my d series harness and get a obd1 distributer , injectors And alternator and wire up VTec with a chipped p28 , I'm also hearing I have to use a b16 harness all the way to the ecu and use a obd2 step down ,
Old Apr 25, 2014 | 03:39 PM
AK_20_EM1's Avatar
Default Re: B20v in eg
really doesnt matter what harness you use...obd1 harness = obd1 distributor, injectors, and alternator... obd2 harness = obd2 distributor, injectors, and alternator... all depends on what you already have really. if you have a eg, all you need is a obd1 ecu, no need for a jumper harness. and obviously any obd1 vtec ecu or chipped at that
Old Apr 25, 2014 | 04:21 PM
KidDxbOrI's Avatar
So basically your saying I have to use a b16 harness ? Will that harness plug to my shock towers harness ?
Old Apr 28, 2014 | 06:33 AM
Recaro's Avatar
No he's saying is if you already have a obd1 which we're assuming you already do because you have an EG, then all you need is obd1 components such add injectors, dizzy, etc. if the wire harness is a non vtec then you have to wire vtec yourself, if it's vtec harness then you're good all you need is a chipped p28 with a base map.
Eddydc2
Nov 3, 2015 02:50 PM
toolbox21
Jun 12, 2012 09:50 AM
nolanator6
Feb 23, 2011 03:19 PM
g356gear
Aug 11, 2008 09:41 PM
akteamster
Feb 7, 2006 07:18 AM
