poor orange spark issue (all new)
hi, I'm having rev. issues and hard starts for a while, all four sparks are orange.
I swap 3 different distributors and two ECU's.
The coil and the ignitor are getting battery voltage.
This last dizzy comes from a running b18c5 and I put New OEM rotor, cap, NGK wires and plugs. And the same orange spark and hard start.
The car 97 EX
ls/vtec
Any tip where I can look to fix this issue?
Thanks in advance
The car 97 EX
ls/vtec
Thanks in advance
Check your coil fuse. It's under the dash, and should be a 20a fuse. Make sure it's the right amperage, then remove it, inspect the prongs for corrosion, and resistance test between the prongs.
Check the contacts and put a new fuse.
Turn the switch to ONII, with test light check both sides of the fuse (light ON).
Voltmeter set to resistance, switch to ONII = 001
Still the same.
Still the same.
tatz9977
May 28, 2012 07:47 PM
