Why shouldn't I?
Old Apr 24, 2014 | 08:43 PM
BseriesEKhatch's Avatar
Default Why shouldn't I?
Disassemble my distributor assembly? CYP CKF TDC sensors. I saw this picture but no reason as to why not. http://www.justanswer.com/honda/4h70x-95-accord-2-2-replace-distributor-check-fix.html
Old Apr 25, 2014 | 12:24 AM
Runnerdown's Avatar
Default Re: Why shouldn't I?
Sure you can. But I think what they are trying to say if there is a problem replace the entire unit. They don't individually sell the sensors. If you can fiddle around or take one from a spare distributor go for it.
For most dealerships and repair shops the best way of avoiding tow trucks or warranty concerns is replace the units as a whole. For the technically savy DIY kind of person, anything goes.
Old Apr 25, 2014 | 02:19 AM
racin97's Avatar
When i worked as a Honda tech at our dealership I/we used to replace internal stuff in distributors. Just remember how it goes together.
Old Apr 25, 2014 | 04:39 AM
That's what I thought but I took mine out and now when I re assemble it the lowest sensor an the magnetic pickup on the drive shaft are interfering. When I put the shaft in and try to rotate it they hit and I can force it past it but it doesn't spin freely. Any ideas why?
Old Apr 25, 2014 | 04:56 AM
doitpropa's Avatar
if i remember correctly the lower sensors have a little slot where the screw down loosen it a little then put shaft in then tighten the screws id imagine theres a tolerance between the 2 prolly need a feeler gauge
Old Apr 25, 2014 | 05:57 AM
rudebwoy's Avatar
I do this all the time, when I have a for example a broken bseries distributor and cannot get an imediate replacement, I take the internals from a D series or similar and put it in the shell of the B series.
Old Apr 25, 2014 | 05:43 PM
So I got home and took it all apart again and it turns out one of the hold down screws for another sensor got stuck to the bottom of the magnet and I didnt see it when I put it together. Took the screw off and tried again. Works perfectly. Thanks for all the help. I was worried I fucked up my dizzy for a bit there haha
04silvep3
Dec 8, 2008 10:54 AM
Ideal
Oct 13, 2005 04:36 AM
Dohcvtec59
Jan 6, 2005 08:00 PM
typeeg
Jun 22, 2004 01:23 PM
pelotudo
Feb 19, 2002 03:03 PM
