Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Adjust idle speed
Old Apr 24, 2014 | 04:41 PM
escknx's Avatar
Default Adjust idle speed
Is there possible to adjust idle rpm to make it little bit higher on Civic Hybrid 2nd gen?
Old Apr 24, 2014 | 04:52 PM
95accordCE6's Avatar
Default Re: Adjust idle speed
Why so you want the idle higher?
Old Apr 24, 2014 | 04:53 PM
*do*
Old Apr 24, 2014 | 05:09 PM
DaveSi677's Avatar
I'm not even sure that is possible since it's all mostly controlled electronically.
Old Apr 24, 2014 | 05:19 PM
Drive by wire I believe, I'm just wondering why it would be beneficial to adjust it if possible
Old Apr 24, 2014 | 06:51 PM
escknx's Avatar
Cause increasing idle rpm for a few dozens may help to get rid of vibration.
Any other options how to fix vibration? I feel it on the steering wheel while on warm idle.
When car is cold idle speed is higher so i do not feel any vibration.
Old Apr 24, 2014 | 10:03 PM
DaveSi677's Avatar
That is not how you solve an issue like that by increasing idle speed.
If you are having vibration it might be a motor mount.
Old May 9, 2014 | 08:15 AM
vladd's Avatar
I would fix the underlying issue rather than apply band-aids. Bad motor mounts can lead to damaging your axles, for example.
axis11
May 16, 2013 08:16 PM
Toanz
Jun 7, 2008 02:02 PM
flood
Mar 30, 2005 08:46 AM
MVK
Jan 9, 2005 03:59 PM
