New Battery, New starter, still wont start.
Old Apr 23, 2014 | 08:22 PM
zc_mike's Avatar
Default New Battery, New starter, still wont start.
I'm thinking it's not grounded, but maybe someone else has had same problem.
My starter was fried (Had to push start everywhere)
Got the starter, went ahead and replaced the four year old battery, and still won't crank over.
Has a fast paced clicking sound from starter, it just will not turn over.
Any ideas?
I'm running new grounds tomorrow, but any input will help!
this is in a 92 civic CX with ZC swap, manual.
Old Apr 23, 2014 | 08:27 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: New Battery, New starter, still wont start.
is your 1972 nova auto or manual?
Old Apr 23, 2014 | 08:29 PM
zc_mike's Avatar
manual.
The starter is getting power to it, so it's not the clutch safety switch, or neutral safety switch, whatever you wanna call it.
Old Apr 24, 2014 | 05:08 AM
moss500's Avatar
If you haven't, take a look at the fuses, see if your starter signal or another is blown.
Old Apr 24, 2014 | 06:37 AM
mikekh10a's Avatar
besides grounding, there could be other problems in the wiring.
1 problem i've ran into personally is corrosion on the wire going to the fusebox. poured some coca cola on it, and it was all better.
Old Apr 24, 2014 | 11:40 AM
ElectronBlue00's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%2A%2A%2A-basics-no-start-diagnosis-101-%2A%2A%2A-1992733/
Go through this, and if you have any issues after this... let us know.
Old Apr 24, 2014 | 07:52 PM
zc_mike's Avatar
Alright!
Got it solved.
I cleaned up all grounds, and went to local auto store, bought a meter of 4 gauge grounding wire, ran it from negative terminal (With new terminal connectors), and ran it to engine.
Runs like a ******* charm and turned over first time after that.
Thanks for all help!
street_ride14
Aug 25, 2014 05:20 PM
wastedfaith
38
Jul 10, 2011 03:14 PM
Din
Jun 27, 2011 11:18 AM
go2sleep
May 6, 2007 08:42 PM
ZexyAccord
Jan 9, 2006 03:34 PM
