Need help rewiring a car battery up front?
Old Apr 23, 2014 | 06:51 PM
Tcoy23's Avatar
Icon2 Need help rewiring a car battery up front?
Hey guys, after searching for awhile all over the place I can't seem to find an answer for my problem. I just picked up a 2000 Honda civic si, and the guy before me wired the battery in the trunk. The power wire has been ran to the battery in the trunk with like a 6 gauge power wire for an amp and the car barely starts without the battery almost dieing. I'm wanting to put the battery back up front underneath the hood but I'm not exactly sure where to wire everything. I already have the battery tray bolted back in and I'm buying a new battery come Friday. Any help would be greatly appreciated.
Old Apr 23, 2014 | 08:37 PM
Runnerdown's Avatar
Default Re: Need help rewiring a car battery up front?
You will need a battery cable to connect the positive terminal to the starter motor and underhood fuse block. Just follow the wires that were there when you bought the car they should already be there. Better off finding an oem cable somewhere.
The ground goes directly to the chassis on the shock tower.
Old Apr 23, 2014 | 11:39 PM
Tcoy23's Avatar
I don't need to run a wire to the alternator?
Old Apr 24, 2014 | 12:17 AM
Runnerdown's Avatar
The oem engine harness has the alternator wire going into the fusebox next to the battery. But if people have been relocating things or hacking the harness anything is possible...
91EF919
Apr 6, 2009 08:27 PM
simonEp3
Jun 25, 2008 01:11 PM
rdeezy78
Audio / Security / Video
10
Aug 27, 2007 03:16 PM
Keith P
Mar 22, 2004 12:59 AM
