Car running rough
Old Apr 22, 2014 | 10:10 PM
94hatchlyfe's Avatar
Default Car running rough
Hey guys i have a 94 civic hatch. I have a carbon fiber hood that has holes or scoops or whatever you wanna call it. When it rains my car does this thing after driving down the road a little where i can rev it for like 2 seconds then it just bogs down. Even when i have my gas petal all the way down. After holding my foot down after a few seconds it will rev up again then repeat the process for 20 or so minutes. If i try to put it in to gear it will go then stop, go then stop. I dont know what the problem is. Could it be because the distributor is getting wet? that was my first thought. Let me know what you think.
Old Apr 24, 2014 | 08:17 AM
skylerreniger's Avatar
Default Re: Car running rough
thats what i was thinking was the distributor getting wet. Have you tried taking the cap off and seeing if there was any moisture built up in there?
Old May 2, 2014 | 06:36 AM
no but i will look!
Old May 4, 2014 | 10:56 PM
SpokaneSpeed's Avatar
Originally Posted by 94hatchlyfe
no but i will look!
Definitely check the cap for moisture on inside WHEN ITS having issues...
Old May 8, 2014 | 07:00 PM
You Mad Bro?'s Avatar
also take note of anything that should not be getting wet but has moisture, like your air intake and such
Old May 8, 2014 | 08:26 PM
SIGNHANG1's Avatar
WD-40 Displaces water instantly !!! Will be good to check if that is the problem !
NoItsNotHerEk9
Apr 20, 2011 05:36 PM
outlawcry7
Jun 22, 2007 11:25 AM
illagee
Dec 2, 2005 08:59 AM
TurboRedSi
Dec 10, 2004 08:44 PM
