Should I spend $4000 on a B16/B20 or work my B16a2?
Old Apr 22, 2014 | 04:12 AM
Shaaks69's Avatar
Icon2 Should I spend $4000 on a B16/B20 or work my B16a2?
I've got a 1994 DelSol and I've been reading around the net and I got a quote from a experienced mechanic on a B16/B20 conversion, it includes installation, dyno tuning, B20b engine and a Hondata S300 Ecu which adds up to $4000, so I'm wondering should I spend that $4000 on something else? If so any ideas?
Old Apr 22, 2014 | 04:36 AM
92HatchHybrid's Avatar
Default Re: Should I spend $4000 on a B16/B20 or work my B16a2?
Another good idea could be purchase a GSR motor for a little more very reliable hp. They sell for around 2000 for long blocks often.
I guess knowing what you would like out of your car would help too or what you plan on doing with it.
Old Apr 22, 2014 | 06:59 AM
Shaaks69's Avatar
I was thinking of putting a B18cr but thought I should as for opinions on my budget. My goals are what are the best and reliable ways of achieving more hp out of my car with a maximum $4000 budget, do you recommend spending it on a B16/B20 or B18cr or just work my B16?
I've been reading plenty of threads but I really haven't got a simple or straight forward answer
Old Apr 22, 2014 | 07:39 AM
Well most power for the buck would be a simple turbo kit. Keep the boost down to a reliable 10-14 and the B16 would be just fine.
Bang for the buck Id buy a gsr long block for 2000 and put that in as it basically bolts right in. That isnt going to be any where as quick as a turbo b16 though. But alot more reliable.
Old Apr 22, 2014 | 05:37 PM
Shaaks69's Avatar
Turbo would be pretty awesome but as of NSW laws no p plater is able to drive turbo, I should've been more specific
I'll do more research on the gsr swap but if I do stick with my B16 what mods do you recommend ? Thanks for your help !
Old Apr 23, 2014 | 07:25 AM
NSW Laws? P plater? Thats new to me. I just noticed do not live in USA.
As far as the B16 and extracting alot of power out of it all motor I am a bit negative on that as hp per dollar spent is not a very good ratio. Maybe bolt ons and a mild cam would be reliable. That minor B20 build isnt a horrible option either just dont go too crazy on compression and it should stay together.
Good luck.
Old Apr 23, 2014 | 03:02 PM
Shaaks69's Avatar
Here in Australia you have to go through certain levels to be able to gain your full license, there is learner, provisional 1 and provisional 2, they all have different restrictions, so pointless
Anyways champ thanks a lot, I'll doo more research !
madmoto154
Dec 11, 2008 09:08 AM
bayron
Aug 19, 2008 01:56 PM
egreenmachine
Aug 3, 2006 01:55 AM
mattssi
13
May 1, 2004 12:57 PM
jDMJeRk
Dec 27, 2003 08:40 AM
