Guy gave me the wrong cluster or something?
I Went to the wreckers and asked for a 96-00 Honda civic cluster the guy gave me one (has a tachometer, mine didn't) I tried to install it but it doesn't have a slot for the orange pin, if i need to plug that in..
pics here
Help is greatly appreciated
pics here
the yellow plug is for srs, you should have a yellow connector for it. plug the other two wire ends into their respective places, make sure theyre connected securely. fyi- you can put your odometer/speedometer into that cluster to retain accurate mileage
I plugged everything in but no rev and stuff.. could the cluster be broken?/ what is that orange cable for
that plug is for abs, which i dont think you have. unless you yanked on the harness or have some other wiring issue, the cluster is faulty.
Could the thing down the bottem left on the second pic be a possible fault?
i didnt notice that, that is almost certainly your problem. those copper leads are the circuitry for the cluster, those two are shot.
Yes they look bad (the power + and - trace might be broken). If the temperature gauge don't work, you can jumper the temp + to the tach. + and the temp - to the tach -.
Roryz
14
Apr 23, 2014 02:16 AM
integraXTC
10
Jun 12, 2011 02:43 PM
sohcvtec91hatch
Jan 24, 2007 02:12 PM
sol2hatch
Feb 9, 2006 08:43 PM
