Clunking noise when braking/accelerating hard or hitting bumps
Old Apr 21, 2014 | 06:21 PM
woodenchef's Avatar
Default Clunking noise when braking/accelerating hard or hitting bumps
I have a 1991 civic wagon with HSDS. I still have about 1/2 inch gap between tire and fender. Whenever I break hard or accelerate hard I hear a clunking sound like something hitting something. I took my front tires off and the fork connected to the coil overs only has like 3/8 to the drive shaft. I will get a picture of asap, but I am guessing this is what is hitting. Is there any way to fix this?
Old Apr 21, 2014 | 07:55 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Clunking noise when braking/accelerating hard or hitting bumps
Originally Posted by woodenchef
?.. I took my front tires off and the fork connected to the coil overs only has like 3/8 to the drive shaft...Is there any way to fix this?
Simple. Raise your car an inch or two.
Old Apr 21, 2014 | 08:33 PM
woodenchef's Avatar
My car is not even low compared to half the wagons I have seen on civic wagon with stanced rims etc. Plus I never even adjusted the coils just bought them and put them on, then got an alignment done .I will have to look at it again.
Old Apr 22, 2014 | 05:03 AM
gkssn's Avatar
2 things. One, is the preload set properly ? and two, how did you go about adjusting the height?
Old Apr 22, 2014 | 08:49 AM
91 EF DX's Avatar
Check you motor and trans mounts
Old Apr 22, 2014 | 02:10 PM
woodenchef's Avatar
What do you mean by the preload? The alignment was done at a dealership. I also have a traction bar on my car. I never adjusted the height on the coilovers took them out of the box made put them on made sure everything was tight on them went to dealership and got an alignment done.
What do you mean by check them? My motor and trans mounts are brand new for a EF with a bseries motor.
Old Apr 22, 2014 | 03:42 PM
woodenchef's Avatar
So I took my fronts wheels off and took some pictures of how close the fork was to the traction bar and drive shaft.
Also my 9k coils are in the front and 6ks are in the rear. Is this correct I was assuming most of the weight is in the front of the car front the engine and transmission, so you would want the stiffer springs in the front.
Old Apr 22, 2014 | 03:48 PM
stevenstixx's Avatar
I had the same issue on my 88 STD.. Pulled the front wheels to take a look, noticed that the driver upper control arm (Skunk2 Camber Kit) Had a lot of play where the ball joint is.. Ordered a new one that is expected to be here on Thursday.. So hopefully this will help.. If you find out your issue, please let me know! Good luck!
Old Apr 23, 2014 | 07:39 AM
gkssn's Avatar
Preload is adjusted at the bottom of the spring( where it sits) jack the car up and make sure the spring is not loose. It should only be hand tightened. Also check the top nut on the coil-overs. I have seen many kits come out of the box and this nut needs tightened. When the car is in the air grab the wheel and shake it back and forth,side to side. See if you have any bad bushings or ball joints. If your axle was hitting anything there would be marks on the axle or fork. HSD's are great coilovers btw....great choice !!
99-LS1
Suspension & Brakes
Oct 2, 2011 11:27 AM
kaotikvizion
May 8, 2009 09:46 PM
timntam
Feb 16, 2005 07:58 AM
Ratchback
Feb 7, 2005 04:10 PM
jiGGaMein
Dec 17, 2004 12:38 PM
