troublehsooting wiring
Old Apr 21, 2014 | 01:24 AM
joakwin's Avatar
Default troublehsooting wiring
i have a charging problem
my alt is putting out 12.5volts no matter the rpm
i have a s300 p28 ecu and a obd1 3 wire alternator, (green round connector with a factory plug in the 4th pin hole)
i think the engine harness came out of a edm or uk market civic
i asked my homie to see what vehicle the harness came from
my engine is a d16z6
and i have a yellow top group 34 battery
anyways
the wiring
tested everything with the key on engine off
and disconnected the alt plug
a blue wire, has no power to it
white/green wire, 12v
black/white or maybe yellow 12v to it
im not sure what the blue wire is for
any clues as to why my alt isn't working?
Old Apr 21, 2014 | 01:55 AM
joakwin's Avatar
Default Re: troublehsooting wiring
engine side of the harness came for a D15z3
that doesn't use a ELD
after work today, im gonna see what pin those 3 wires plug into and then I can start to figure out the problem
Old Apr 21, 2014 | 03:59 AM
joakwin's Avatar
took the harness apart at lunch and it seems like im on to something
the blue wire wasn't connected to anything
the white/green is connected to A16
and black/yellow has ign 12v to it
i think its connected to drivers side 303 plug #3, will check when i get home from work, forgot to write it down at lunch time
i think this is how the wiring should be
black/yellow Ign
white/blue dash light
white green A16
blue D9
i dont think i need a dash light for it to work
Old Apr 21, 2014 | 02:54 PM
joakwin's Avatar
I think the alt is done for
I wired in the 4th wire, white/yellow, gave it 12v
black/yellow 12v
white blue to light is working fine
blue has 4.6volts, d9
alt wont put anything out
so im gonna pull it and take it to get tested and maybe rebuilt if it will be cheaper then replacing
time to look up rockauto and autozone
Mauro87
Sep 25, 2011 10:59 AM
clockstick
Oct 27, 2009 06:54 PM
simplypinoyy
Jul 13, 2008 03:23 PM
1 Fly SI
19
Nov 15, 2006 09:14 AM
rca90gsx
Apr 2, 2002 05:07 PM
