Power Steering & Rack & Pinion ??
On start ups in the morning my power steering is acting goofy, kinda jerks loose tight loose and squeals for a few seconds. The belt is less than a year old and there are no power steering fluid leaks, which leads me to the thoughts that it could be Rack related.
Anybody else have this problem or know how to figure out what exactly is going on?
Thanks
Thanks
Well it wouldn't hurt to check out your tie rod ends. The inner and out ones. If they have play or don't move correctly then I would recommend some new ones. The belt noise could be related to the amount of tension applied to the belt. This in your case is controlled by the bracket near the power steering or alternator I believe. Just some thoughts tho
horjoh
Feb 27, 2011 05:51 PM
